iPod Touch 5th Generation Lightning Connector Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPod Touch 5th Generation Lightning Connector Assembly Replacement, Lightning Connector Assembly: step 1, image 1 of 1
    • Use the tip of a spudger to peel back a small piece of tape covering a screw on the left side of the headphone jack.
  2. iPod Touch 5th Generation Lightning Connector Assembly Replacement: step 2, image 1 of 1
    • Remove the following screws securing the headphone jack, Lightning connector, and speaker.
    • Three 2.6 mm #000 Phillips screws
    • Two 2.0 mm #000 Phillips screws
  3. iPod Touch 5th Generation Lightning Connector Assembly Replacement: step 3, image 1 of 1
    • Use the flat end of a spudger to pry the speaker up from the rear case.
    • Do not try to remove the speaker, as it is soldered to the Lightning connector assembly.
  4. iPod Touch 5th Generation Lightning Connector Assembly Replacement: step 4, image 1 of 2 iPod Touch 5th Generation Lightning Connector Assembly Replacement: step 4, image 2 of 2
    • Grasping the large ribbon cable, gently pull the Lightning connector assembly out of the bottom of the case.
Andrew Optimus Goldheart
508,613 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 240
