iPod Touch 7th Generation Rear-Facing Camera Replacement
Tarun Thiruma
Tarun Thiruma and 2 other contributors
Last updated on October 9, 2024
No estimate
Moderate
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
Introduction
Go to step 1
Prerequisite for entire button ribbon cable, volume buttons, power button, and rear case.
Tools
  1. iPod Touch 7th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: step 1, image 1 of 3 iPod Touch 7th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: step 1, image 2 of 3 iPod Touch 7th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: step 1, image 3 of 3
    • Insert the flat end of a spudger between the rear-facing camera and its frame.
    • Gently twist the spudger to free the camera.
    • Lift the rear-facing camera up out of its socket, and remove it from the iPod Touch.
  2. iPod Touch 7th Generation Rear-Facing Camera Replacement: step 2, image 1 of 3 iPod Touch 7th Generation Rear-Facing Camera Replacement: step 2, image 2 of 3 iPod Touch 7th Generation Rear-Facing Camera Replacement: step 2, image 3 of 3
    • Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable.
    • Run the spudger along the full length of the tape to disconnect it from the rear case.
  3. iPod Touch 7th Generation Rear-Facing Camera Replacement: step 3, image 1 of 2 iPod Touch 7th Generation Rear-Facing Camera Replacement: step 3, image 2 of 2
    • Peel and remove the foam tape from the rear case of the iPod.
  4. iPod Touch 7th Generation Rear-Facing Camera Replacement: step 4, image 1 of 3 iPod Touch 7th Generation Rear-Facing Camera Replacement: step 4, image 2 of 3 iPod Touch 7th Generation Rear-Facing Camera Replacement: step 4, image 3 of 3
    Tool used on this step:
    • Use the tip of a spudger to peel up the edge of the tape covering the button ribbon cable.
    • Use tweezers or your fingers to peel the tape up from the rear case, and remove it from the iPod.
Tarun Thiruma
37,819 Reputation
134 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 18
All Time: 27
