iRobot Braava 320 Body Shell Replacement
  1. iRobot Braava 320 Body Shell Replacement, Battery: step 1, image 1 of 1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Body Shell Replacement: step 2, image 1 of 1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Body Shell Replacement: step 3, image 1 of 2 iRobot Braava 320 Body Shell Replacement: step 3, image 2 of 2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
  4. iRobot Braava 320 Body Shell Replacement, Body Shell and Control Panel: step 4, image 1 of 1
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
  5. iRobot Braava 320 Body Shell Replacement: step 5, image 1 of 2 iRobot Braava 320 Body Shell Replacement: step 5, image 2 of 2
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
Adam Lewis
214 Reputation
1 Guide authored
USF Tampa, Team S1-G3, Nance Spring 2017 Member of USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 728
