Introduction
The deck plate assembly is an essential component to the Braava, allowing the device to detect obstacles while moving. With a damaged deck plate assembly, your Braava may encounter mobility issues and may not be able to detect possible obstacles in your home or office. Replacing the deck plate assembly may solve these issues.
With the battery removed, rotate your device so the front of it is facing you.
Remove the four 10mm Phillips #2 screws that attach the shell.
With the shell off, flip the iRobot over and remove the four 10mm Phillips #0 screws holding the deck plate assembly on.
