iRobot Braava Jet 240 Back Shell Replacement
  1. iRobot Braava Jet 240 Back Shell Replacement, Battery: step 1, image 1 of 1
    • Turn the device off.
  2. iRobot Braava Jet 240 Back Shell Replacement: step 2, image 1 of 2 iRobot Braava Jet 240 Back Shell Replacement: step 2, image 2 of 2
    • Use your fingers to gently pop out the battery.
  3. iRobot Braava Jet 240 Back Shell Replacement, Mop Pad: step 3, image 1 of 2 iRobot Braava Jet 240 Back Shell Replacement, Mop Pad: step 3, image 2 of 2
    • Lift up the handle to reveal the eject button.
  4. iRobot Braava Jet 240 Back Shell Replacement: step 4, image 1 of 3 iRobot Braava Jet 240 Back Shell Replacement: step 4, image 2 of 3 iRobot Braava Jet 240 Back Shell Replacement: step 4, image 3 of 3
    • Use your finger to push the eject button forward.
  5. iRobot Braava Jet 240 Back Shell Replacement: step 5, image 1 of 1
    • Tilt the robot on its side and let the mop pad slide out.
  6. iRobot Braava Jet 240 Back Shell Replacement, Front Shell: step 6, image 1 of 2 iRobot Braava Jet 240 Back Shell Replacement, Front Shell: step 6, image 2 of 2
    • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
  7. iRobot Braava Jet 240 Back Shell Replacement: step 7, image 1 of 2 iRobot Braava Jet 240 Back Shell Replacement: step 7, image 2 of 2
    • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
  8. iRobot Braava Jet 240 Back Shell Replacement: step 8, image 1 of 3 iRobot Braava Jet 240 Back Shell Replacement: step 8, image 2 of 3 iRobot Braava Jet 240 Back Shell Replacement: step 8, image 3 of 3
    • Carefully pull back on the front shell to remove it from the robot.
  9. iRobot Braava Jet 240 Back Shell Replacement, Back Shell: step 9, image 1 of 2 iRobot Braava Jet 240 Back Shell Replacement, Back Shell: step 9, image 2 of 2
    • Insert a Phillips #1 screwdriver through the screw holes.
    • Unscrew the two 9.7 mm screws.
  10. iRobot Braava Jet 240 Back Shell Replacement: step 10, image 1 of 2 iRobot Braava Jet 240 Back Shell Replacement: step 10, image 2 of 2
    • Unscrew the four 9.7 mm screws using a long neck #1 Phillips screwdriver.
    • If the screws are unscrewed but do not come out easily, turn the robot upside down and gently shake it.
  11. iRobot Braava Jet 240 Back Shell Replacement: step 11, image 1 of 3 iRobot Braava Jet 240 Back Shell Replacement: step 11, image 2 of 3 iRobot Braava Jet 240 Back Shell Replacement: step 11, image 3 of 3
    • Pull up on the back shell to remove it from the robot.
    • For reassembly, pop the mop pad release trigger back into place if it fell out during back shell removal.
Claire Franz
2,784 Reputation
7 Guides authored
Cal Poly, Team S22-G2, Regan Winter 2020 Member of Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
5 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 21
All Time: 1,489
