iRobot Braava Jet 240 Front Shell Replacement
  1. iRobot Braava Jet 240 Front Shell Replacement, Battery: step 1, image 1 of 1
    • Turn the device off.
  2. iRobot Braava Jet 240 Front Shell Replacement: step 2, image 1 of 2 iRobot Braava Jet 240 Front Shell Replacement: step 2, image 2 of 2
    • Use your fingers to gently pop out the battery.
  3. iRobot Braava Jet 240 Front Shell Replacement, Mop Pad: step 3, image 1 of 2 iRobot Braava Jet 240 Front Shell Replacement, Mop Pad: step 3, image 2 of 2
    • Lift up the handle to reveal the eject button.
  4. iRobot Braava Jet 240 Front Shell Replacement: step 4, image 1 of 3 iRobot Braava Jet 240 Front Shell Replacement: step 4, image 2 of 3 iRobot Braava Jet 240 Front Shell Replacement: step 4, image 3 of 3
    • Use your finger to push the eject button forward.
  5. iRobot Braava Jet 240 Front Shell Replacement: step 5, image 1 of 1
    • Tilt the robot on its side and let the mop pad slide out.
  6. iRobot Braava Jet 240 Front Shell Replacement, Front Shell: step 6, image 1 of 2 iRobot Braava Jet 240 Front Shell Replacement, Front Shell: step 6, image 2 of 2
    • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
  7. iRobot Braava Jet 240 Front Shell Replacement: step 7, image 1 of 2 iRobot Braava Jet 240 Front Shell Replacement: step 7, image 2 of 2
    • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
  8. iRobot Braava Jet 240 Front Shell Replacement: step 8, image 1 of 3 iRobot Braava Jet 240 Front Shell Replacement: step 8, image 2 of 3 iRobot Braava Jet 240 Front Shell Replacement: step 8, image 3 of 3
    • Carefully pull back on the front shell to remove it from the robot.
Claire Franz
2,784 Reputation
7 Guides authored
Cal Poly, Team S22-G2, Regan Winter 2020 Member of Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
5 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 827
