iRobot Roomba 4160 Battery Replacement
  1. iRobot Roomba 4160 Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure the Roomba is turned off to avoid an electric shock.
    • Turn the Roomba upside down, and place it so that the underside is exposed. The wheels and brushes should be visible.
    • Do not attempt to open up the yellow battery pack. You may get shocked or burned by the battery acid.
  2. iRobot Roomba 4160 Battery Replacement: step 2, image 1 of 2 iRobot Roomba 4160 Battery Replacement: step 2, image 2 of 2
    • Identify the yellow plastic rectangular battery, directly to the right of the spinning brush.
    • Place your index fingers on the small rectangular plastic tabs on both sides of the battery. Push the tabs in until the battery comes loose.
    • Pull battery out using your fingers.
To re-install battery, follow these instructions in reverse order.
Garrett Rasmussen
225 Reputation
2 Guides authored
Cal Poly, Team 6-4, Forte Spring 2014 Member of Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,000
