iRobot Roomba 551 Battery Replacement
  1. iRobot Roomba 551  Battery Replacement, Side Brush: step 1, image 1 of 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551  Battery Replacement: step 2, image 1 of 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551  Battery Replacement: step 3, image 1 of 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551  Battery Replacement, Bottom Plate: step 4, image 1 of 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551  Battery Replacement: step 5, image 1 of 2 iRobot Roomba 551  Battery Replacement: step 5, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551  Battery Replacement: step 6, image 1 of 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551  Battery Replacement, Battery: step 7, image 1 of 2 iRobot Roomba 551  Battery Replacement, Battery: step 7, image 2 of 2
    • Lift and remove the old battery by pulling the tabs on both sides.
    • Gently replace with a new battery.
6 other people completed this guide.
Deborah Newberry
623 Reputation
4 Guides authored
Cal Poly, Team 13-14, Regan Winter 2014 Member of Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Members
19 Guides authored
1 Guide Comment
Thank you Deborah!
James - Reply
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 71
All Time: 11,376
