iRobot Roomba 551 Brushes Replacement
  1. iRobot Roomba 551 Brushes Replacement, Side Brush: step 1, image 1 of 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Brushes Replacement: step 2, image 1 of 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Brushes Replacement: step 3, image 1 of 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Brushes Replacement, Bottom Plate: step 4, image 1 of 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Brushes Replacement: step 5, image 1 of 2 iRobot Roomba 551 Brushes Replacement: step 5, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Brushes Replacement: step 6, image 1 of 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Brushes Replacement, Brushes: step 7, image 1 of 2 iRobot Roomba 551 Brushes Replacement, Brushes: step 7, image 2 of 2
    • Pinch the yellow tabs on the sides of the brush cage and lift up to open.
  8. iRobot Roomba 551 Brushes Replacement: step 8, image 1 of 3 iRobot Roomba 551 Brushes Replacement: step 8, image 2 of 3 iRobot Roomba 551 Brushes Replacement: step 8, image 3 of 3
    • Grab each brush and lift upwards to remove.
John McTigue
331 Reputation
3 Guides authored
Cal Poly, Team 13-14, Regan Winter 2014 Member of Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Members
19 Guides authored
2 Comments
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
Gunnar Nybraten - Reply
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
Christa Eads - Reply
Past 24 Hours: 9
Past 7 Days: 88
Past 30 Days: 414
All Time: 6,986
