iRobot Roomba 551 Side Brush Motor Replacement
  1. iRobot Roomba 551 Side Brush Motor Replacement, Side Brush: step 1, image 1 of 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Side Brush Motor Replacement: step 2, image 1 of 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Side Brush Motor Replacement: step 3, image 1 of 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Side Brush Motor Replacement, Bottom Plate: step 4, image 1 of 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Side Brush Motor Replacement: step 5, image 1 of 2 iRobot Roomba 551 Side Brush Motor Replacement: step 5, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Side Brush Motor Replacement: step 6, image 1 of 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Side Brush Motor Replacement, Side Brush Motor: step 7, image 1 of 3 iRobot Roomba 551 Side Brush Motor Replacement, Side Brush Motor: step 7, image 2 of 3 iRobot Roomba 551 Side Brush Motor Replacement, Side Brush Motor: step 7, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly.
  8. iRobot Roomba 551 Side Brush Motor Replacement: step 8, image 1 of 1
    • Gently pull on motor assembly to remove.
Aaron Jacobs
540 Reputation
4 Guides authored
Cal Poly, Team 13-14, Regan Winter 2014 Member of Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Members
19 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 923
