iRobot Roomba 560 Battery Replacement
  1. iRobot Roomba 560 Battery Replacement, Side Sweeper: step 1, image 1 of 1
    • Flip the Roomba upside down.
    • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
  2. iRobot Roomba 560 Battery Replacement: step 2, image 1 of 1
    • Lift the yellow side sweeper, removing it from the device.
  3. iRobot Roomba 560 Battery Replacement, Battery: step 3, image 1 of 1
    • Using the Phillips #2 driver, remove the four 10 mm screws that hold the back panel in place.
  4. iRobot Roomba 560 Battery Replacement: step 4, image 1 of 1
    • Lift up the back panel to remove it from the device.
  5. iRobot Roomba 560 Battery Replacement: step 5, image 1 of 2 iRobot Roomba 560 Battery Replacement: step 5, image 2 of 2
    • Lift up the yellow battery by pulling up the green tabs on its side.
    • Handle the battery with care.
10 other people completed this guide.
Mairead Blaes
825 Reputation
4 Guides authored
Cal Poly, Team 1-22, Maness Fall 2015 Member of Cal Poly, Team 1-22, Maness Fall 2015
CPSU-MANESS-F15S1G22
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 26
All Time: 5,484
