iRobot Roomba 560 Side Sweeper Replacement
  1. iRobot Roomba 560 Side Sweeper Replacement, Side Sweeper: step 1, image 1 of 1
    • Flip the Roomba upside down.
    • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
  2. iRobot Roomba 560 Side Sweeper Replacement: step 2, image 1 of 1
    • Lift the yellow side sweeper, removing it from the device.
3 other people completed this guide.
Mairead Blaes
825 Reputation
4 Guides authored
Cal Poly, Team 1-22, Maness Fall 2015 Member of Cal Poly, Team 1-22, Maness Fall 2015
CPSU-MANESS-F15S1G22
4 Members
14 Guides authored
2 Comments
I need to replace the part on the bottom where the side sweeper screws in. The threads are stripped, I’m guessing, and screw won’t stay in.
Candy Schnurr - Reply
put some hot glue or melt some plastic in the hole before screwing it. you should get the threads back when you unscrew it
Nicolas Sicard -
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 22
All Time: 1,713
