iRobot Roomba 595 Pet Series Side Brush Motor Replacement
  1. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Secondary Brush: step 1, image 1 of 1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: step 2, image 1 of 1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: step 3, image 1 of 2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: step 3, image 2 of 2
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Lift the external underside cover accordingly.
  4. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: step 4, image 1 of 1
    • Use the Phillips #0 screwdriver bit to remove the three 15mm screws.
  5. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: step 5, image 1 of 2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: step 5, image 2 of 2
    • Remove the motor from the blue casing.
Dale Shirley-Potopsingh
446 Reputation
4 Guides authored
USF Tampa, Team S10-G5, Thompson Fall 2017 Member of USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
3 Members
5 Guides authored
2 Comments
I changed the motor and still does not work.
Jose - Reply
I changed the motor and still did not work.
Jose - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 730
