iRobot Roomba 595 Pet Series Main Brush Replacement
  1. iRobot Roomba 595 Pet Series Main Brush Replacement, Secondary Brush: step 1, image 1 of 1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Main Brush Replacement: step 2, image 1 of 1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Main Brush Replacement, Main Brush: step 3, image 1 of 2 iRobot Roomba 595 Pet Series Main Brush Replacement, Main Brush: step 3, image 2 of 2
    • Remove the four 10mm screws with a Phillips #1 screwdriver. Gently lift off the external covering for the Roomba's underside.
  4. iRobot Roomba 595 Pet Series Main Brush Replacement: step 4, image 1 of 3 iRobot Roomba 595 Pet Series Main Brush Replacement: step 4, image 2 of 3 iRobot Roomba 595 Pet Series Main Brush Replacement: step 4, image 3 of 3
    • Press lightly on the yellow tabs and lift the cage cover containing the brush.
  5. iRobot Roomba 595 Pet Series Main Brush Replacement: step 5, image 1 of 2 iRobot Roomba 595 Pet Series Main Brush Replacement: step 5, image 2 of 2
    • Lift the brush from the right side and slide it from its container within the Roomba.
Dale Shirley-Potopsingh
446 Reputation
4 Guides authored
USF Tampa, Team S10-G5, Thompson Fall 2017 Member of USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 10
All Time: 623
