iRobot Roomba 650 Caster Wheel Replacement
  1. iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: step 1, image 1 of 2 iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: step 1, image 2 of 2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: step 2, image 1 of 2 iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: step 2, image 2 of 2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Caster Wheel Replacement, Caster Wheel: step 3, image 1 of 1
    • Begin by pulling on the caster wheel. It should pop out of its housing fairly easily.
  4. iRobot Roomba 650 Caster Wheel Replacement: step 4, image 1 of 2 iRobot Roomba 650 Caster Wheel Replacement: step 4, image 2 of 2
    • Once caster wheel is off the Roomba, push on the wheel so that it slides out of the groves it sits in.
2 other people completed this guide.
Alex Schnorr
628 Reputation
3 Guides authored
Cal Poly, Team 19-7, Maness Winter 2015 Member of Cal Poly, Team 19-7, Maness Winter 2015
CPSU-MANESS-W15S19G7
4 Members
6 Guides authored
3 Comments
Alternate instructions.
1. skip steps 1 and 2. you don't need to take the panel off to remove the caster wheel.
2. follow steps 3 and 4.
Matt Johnson - Reply
Worked for my 690 as well.
Luke Oliver - Reply
Hi, my caster wheel drops out easiy from the groves… a bit like the groves are worn out already and are no longer able to hold the wheel metal spoke in place. I would like to know if this can be fixed without resorting to buying a new wheel? (Reduce, Reuse, Recycle) Please help?
Rykel Lim - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 2,187
