iRobot Roomba 655 Pet Series Brush Motor Replacement
  1. iRobot Roomba 655 Pet Series Brush Motor Replacement, Removing the Side Brush: step 1, image 1 of 2 iRobot Roomba 655 Pet Series Brush Motor Replacement, Removing the Side Brush: step 1, image 2 of 2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Brush Motor Replacement, Removing the Back Panel: step 2, image 1 of 2 iRobot Roomba 655 Pet Series Brush Motor Replacement, Removing the Back Panel: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Brush Motor Replacement, Removing the Battery: step 3, image 1 of 3 iRobot Roomba 655 Pet Series Brush Motor Replacement, Removing the Battery: step 3, image 2 of 3 iRobot Roomba 655 Pet Series Brush Motor Replacement, Removing the Battery: step 3, image 3 of 3
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Brush Motor Replacement, Battery Contact Points: step 4, image 1 of 2 iRobot Roomba 655 Pet Series Brush Motor Replacement, Battery Contact Points: step 4, image 2 of 2
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
  5. iRobot Roomba 655 Pet Series Brush Motor Replacement, Brush Motor Removal: step 5, image 1 of 3 iRobot Roomba 655 Pet Series Brush Motor Replacement, Brush Motor Removal: step 5, image 2 of 3 iRobot Roomba 655 Pet Series Brush Motor Replacement, Brush Motor Removal: step 5, image 3 of 3
    • Insert a spudger into the side to pop out one side of the brush holder.
    • Repeat the same step, but now on the other side of the brush holder.
    • Lift the gray plastic piece up carefully to expose the motor.
    • Do not pull up too hard because you could snap a wire attached to the motor or motor circuit board.
  6. iRobot Roomba 655 Pet Series Brush Motor Replacement: step 6, image 1 of 2 iRobot Roomba 655 Pet Series Brush Motor Replacement: step 6, image 2 of 2
    • Use a Phillips #0 to remove the two 6 mm screws securing the green circuit board protector.
    • Remove the 6mm Phillips screw attaching the circuit board. Doing so should give you access to the circuit board.
  7. iRobot Roomba 655 Pet Series Brush Motor Replacement: step 7, image 1 of 2 iRobot Roomba 655 Pet Series Brush Motor Replacement: step 7, image 2 of 2
    • These rubber rings protect the motor circuit board from dust accumulated in the Roomba.
    • Do not lose these rubber rings.
    • Remove the two - 7mm screws that connect the motor to the grey plastic protector. Use a Phillips head #0 this time.
  8. iRobot Roomba 655 Pet Series Brush Motor Replacement: step 8, image 1 of 2 iRobot Roomba 655 Pet Series Brush Motor Replacement: step 8, image 2 of 2
  9. iRobot Roomba 655 Pet Series Brush Motor Replacement: step 9, image 1 of 3 iRobot Roomba 655 Pet Series Brush Motor Replacement: step 9, image 2 of 3 iRobot Roomba 655 Pet Series Brush Motor Replacement: step 9, image 3 of 3
    • Option A: Some motors can unclip from the wiring harness. Use the spudger to pry the white colored base of the motor from the gray piece on the end.
    • Clip the new motor into the gray plastic in the same configuration you removed the original motor.
    • Option B: If your replacement motor does not have wires pre-attached, snip the existing wires near the base of the motor.
    • Solder the snipped wires to the base of the new motor in the same configuration they were with the original motor.
    • Option C: If your new motor has wires pre-attached, splice the original wires with the respective wires from the original motor.
Matt Davis
1,642 Reputation
7 Guides authored
Cal Poly, Team 21-20, Maness Winter 2015 Member of Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 15
All Time: 2,809
