iRobot Roomba 655 Pet Series Display Replacement
  1. iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: step 1, image 1 of 2 iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: step 1, image 2 of 2
    • Remove the dust bin by pushing on the button for the dust bin removal
    • Pull the dust bin out
  2. iRobot Roomba 655 Pet Series Display  Replacement: step 2, image 1 of 2 iRobot Roomba 655 Pet Series Display  Replacement: step 2, image 2 of 2
    • Pull up on the silver handle to release the top protectant plastic
    • Remove the top plastic carefully
  3. iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: step 3, image 1 of 2 iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: step 3, image 2 of 2
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  4. iRobot Roomba 655 Pet Series Display  Replacement: step 4, image 1 of 3 iRobot Roomba 655 Pet Series Display  Replacement: step 4, image 2 of 3 iRobot Roomba 655 Pet Series Display  Replacement: step 4, image 3 of 3
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
  5. iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: step 5, image 1 of 3 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: step 5, image 2 of 3 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: step 5, image 3 of 3
    • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
    • Use your Phillips head #0 to remove the one - 7mm bottom center screw
    • Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • Push down the two release points to pull the plastic piece up
    • Pull the plastic piece up
  6. iRobot Roomba 655 Pet Series Display  Replacement, Display: step 6, image 1 of 3 iRobot Roomba 655 Pet Series Display  Replacement, Display: step 6, image 2 of 3 iRobot Roomba 655 Pet Series Display  Replacement, Display: step 6, image 3 of 3
    • Pull the silver tab, and clear tinted display off
    • Remove the 4 - 9mm screws holding the display with your Phillips head #0
  7. iRobot Roomba 655 Pet Series Display  Replacement: step 7, image 1 of 3 iRobot Roomba 655 Pet Series Display  Replacement: step 7, image 2 of 3 iRobot Roomba 655 Pet Series Display  Replacement: step 7, image 3 of 3
    • Remove the display
    • Remove the plastic protectant film from the motherboard
Rhett
1,350 Reputation
7 Guides authored
Cal Poly, Team 21-20, Maness Winter 2015 Member of Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 899
