iRobot Roomba 655 Pet Series Drive Wheels Replacement
  1. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: step 1, image 1 of 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: step 1, image 2 of 2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: step 2, image 1 of 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: step 3, image 1 of 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: step 3, image 2 of 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: step 3, image 3 of 3
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: step 4, image 1 of 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: step 4, image 2 of 2
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
  5. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: step 5, image 1 of 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: step 5, image 2 of 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: step 5, image 3 of 3
    • Remove the three screws with your Phillips head #1, holding the drive wheels in place
    • These three screws will stay in place and won't come out of the plastic
  6. iRobot Roomba 655 Pet Series Drive Wheels Replacement: step 6, image 1 of 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement: step 6, image 2 of 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement: step 6, image 3 of 3
    • Unscrew the actual wheel from the blue plastic holder
    • Pull apart the blue holder to completely remove the wheel
  7. iRobot Roomba 655 Pet Series Drive Wheels Replacement: step 7, image 1 of 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement: step 7, image 2 of 2
    • To go further into the holder to access the programming chips you can unscrew these compartments
Rhett
1,329 Reputation
7 Guides authored
Cal Poly, Team 21-20, Maness Winter 2015 Member of Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 2,286
