iRobot Roomba 655 Pet Series Side Brush Motor Replacement
  1. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: step 1, image 1 of 3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: step 1, image 2 of 3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: step 1, image 3 of 3
    • First start by removing the two - 6mm screws with your Phillips head #1, that unlock the motor from your Roomba
    • Pull the brush motor out
  2. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: step 2, image 1 of 3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: step 2, image 2 of 3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: step 2, image 3 of 3
    • Next, with the same head remove the screw holding the plastic housing together
    • Carefully pry the gear box open by placing a flat head screwdriver in the slot
    • This might be difficult and require some shifting of the screwdriver
  3. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: step 3, image 1 of 3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: step 3, image 2 of 3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: step 3, image 3 of 3
    • Removing these two screws will allow you to access the motor (use the same head as before)
2 other people completed this guide.
Matt Davis
1,642 Reputation
7 Guides authored
Cal Poly, Team 21-20, Maness Winter 2015 Member of Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,664
