iRobot Roomba 690 Battery Replacement
  1. iRobot Roomba 690 Battery Replacement, Spinning Brush: step 1, image 1 of 1
    • Place the Roomba upside down so that the wheels and brushes are facing upward.
  2. iRobot Roomba 690 Battery Replacement: step 2, image 1 of 3 iRobot Roomba 690 Battery Replacement: step 2, image 2 of 3 iRobot Roomba 690 Battery Replacement: step 2, image 3 of 3
    • Loosen the captive screw in the spinning brush using a Phillips #0 screwdriver.
    • Remove the spinning brush from the vacuum.
  3. iRobot Roomba 690 Battery Replacement, Battery: step 3, image 1 of 1
    • Remove the four 6.4 mm screws from the bottom of the Roomba using a Phillips #0 screwdriver.
    • They are labeled with triangular arrows next to them on the cover.
  4. iRobot Roomba 690 Battery Replacement: step 4, image 1 of 1
    • Lift the bottom cover up from the rest of the Roomba.
  5. iRobot Roomba 690 Battery Replacement: step 5, image 1 of 3 iRobot Roomba 690 Battery Replacement: step 5, image 2 of 3 iRobot Roomba 690 Battery Replacement: step 5, image 3 of 3
    • Lift out the battery by pulling up on the two flexible tabs that are attached to the left and right sides.
John Galvin
584 Reputation
5 Guides authored
One Comment
Thanks, super easy and great pictorial instruction.
Faythe2Faythe - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 32
All Time: 988
