iRobot Roomba 690 Drive Wheels Replacement
  1. iRobot Roomba 690 Drive Wheels Replacement, Spinning Brush: step 1, image 1 of 1
    • Place the Roomba upside down so that the wheels and brushes are facing upward.
  2. iRobot Roomba 690 Drive Wheels Replacement: step 2, image 1 of 3 iRobot Roomba 690 Drive Wheels Replacement: step 2, image 2 of 3 iRobot Roomba 690 Drive Wheels Replacement: step 2, image 3 of 3
    • Loosen the captive screw in the spinning brush using a Phillips #0 screwdriver.
    • Remove the spinning brush from the vacuum.
  3. iRobot Roomba 690 Drive Wheels Replacement, Battery: step 3, image 1 of 1
    • Remove the four 6.4 mm screws from the bottom of the Roomba using a Phillips #0 screwdriver.
    • They are labeled with triangular arrows next to them on the cover.
  4. iRobot Roomba 690 Drive Wheels Replacement: step 4, image 1 of 1
    • Lift the bottom cover up from the rest of the Roomba.
  5. iRobot Roomba 690 Drive Wheels Replacement: step 5, image 1 of 3 iRobot Roomba 690 Drive Wheels Replacement: step 5, image 2 of 3 iRobot Roomba 690 Drive Wheels Replacement: step 5, image 3 of 3
    • Lift out the battery by pulling up on the two flexible tabs that are attached to the left and right sides.
  6. iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: step 6, image 1 of 2 iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: step 6, image 2 of 2
    • Each drive wheel is labeled left and right.
    • Remove three 12 mm screws from each drive wheel using a Phillips #0 screwdriver.
    • Remove the drive wheels from the vacuum.
John Galvin
584 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 481
