iRobot Roomba 692 Battery Replacement
  1. iRobot Roomba 692 Battery Replacement, Battery: step 1, image 1 of 3 iRobot Roomba 692 Battery Replacement, Battery: step 1, image 2 of 3 iRobot Roomba 692 Battery Replacement, Battery: step 1, image 3 of 3
    • To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
    • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 692 Battery Replacement: step 2, image 1 of 3 iRobot Roomba 692 Battery Replacement: step 2, image 2 of 3 iRobot Roomba 692 Battery Replacement: step 2, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the four black 3.5 mm screws on the bottom panel.
    • Remove the bottom panel.
    • Can't find the screws? Refer to the red circles in the Step 1 image.
  3. iRobot Roomba 692 Battery Replacement: step 3, image 1 of 3 iRobot Roomba 692 Battery Replacement: step 3, image 2 of 3 iRobot Roomba 692 Battery Replacement: step 3, image 3 of 3
    • Using the black tabs on both short ends of the battery pack, gently pull the battery up and out of its slot.
Demi Muyuela
483 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 70
All Time: 972
