iRobot Roomba 692 Filter Replacement
  1. iRobot Roomba 692 Filter Replacement, Dustbin: step 1, image 1 of 1
    • Rotate the Roomba so that the "R" on top is facing toward you
    • Press the button at the bottom of the Roomba
  2. iRobot Roomba 692 Filter Replacement: step 2, image 1 of 3 iRobot Roomba 692 Filter Replacement: step 2, image 2 of 3 iRobot Roomba 692 Filter Replacement: step 2, image 3 of 3
    • Press down on the button and lightly pull until the dustbin is fully removed from the Roomba.
  3. iRobot Roomba 692 Filter Replacement: step 3, image 1 of 1
    • Pull on the yellow tab to open the filter latch.
    • The dustbin can now be emptied or cleaned.
  4. iRobot Roomba 692 Filter Replacement, Filter: step 4, image 1 of 2 iRobot Roomba 692 Filter Replacement, Filter: step 4, image 2 of 2
    • Flip over the dustbin so that the clear side is facing upward.
    • Now the green tabs to remove the filter are visible.
  5. iRobot Roomba 692 Filter Replacement: step 5, image 1 of 3 iRobot Roomba 692 Filter Replacement: step 5, image 2 of 3 iRobot Roomba 692 Filter Replacement: step 5, image 3 of 3
    • Pinch and pull up on the green tabs with index finger and thumb.
This guide will help you replace filter from dustbin.
Ruth Oliva
217 Reputation
2 Guides authored
IUPUI, Team 1-1, Harley Fall 2023 Member of IUPUI, Team 1-1, Harley Fall 2023
IUPUI-HARLEY-F23S1G1
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 134
