iRobot Roomba 770 Brush Replacement
  1. iRobot Roomba 770 Brush Replacement, Brush: step 1, image 1 of 1
    • Orient the roomba so it is upside down and the dust tray is closest to you.
  2. iRobot Roomba 770 Brush Replacement: step 2, image 1 of 2 iRobot Roomba 770 Brush Replacement: step 2, image 2 of 2
    • Locate the two yellow tabs on the screen that covers the brushes.
    • Push inwards on the yellow tabs while simultaneously pulling upwards on the attached grey cage.
  3. iRobot Roomba 770 Brush Replacement: step 3, image 1 of 3 iRobot Roomba 770 Brush Replacement: step 3, image 2 of 3 iRobot Roomba 770 Brush Replacement: step 3, image 3 of 3
    • Grab the right side of the larger brush that is located near the yellow cap. Pull upwards and to the right to remove the brush.
    • Repeat the same steps with the smaller brush.
  4. iRobot Roomba 770 Brush Replacement: step 4, image 1 of 2 iRobot Roomba 770 Brush Replacement: step 4, image 2 of 2
    • Orient the brush so the yellow tab is on the right hand side.
    • Pull the yellow tab to the right to remove.
    • Remove any debris, paying attention to the ends as well as the brush itself.
    • Replace any damaged brushes.
Andrew Horvath
444 Reputation
3 Guides authored
Cal Poly, Team 15-3, Livingston Fall 2016 Member of Cal Poly, Team 15-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G3
3 Members
5 Guides authored
One Comment
My roomba starts and moves a foot or so and then stops. I have cleaned it entirely, the battery is fine and the wheels are clean. Anyone have a suggestion
Mary Ann Dyer - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 2,326
