iRobot Roomba 870 Main Wheel Replacement
  1. iRobot Roomba 870 Main Wheel Replacement, Main Wheel: step 1, image 1 of 2 iRobot Roomba 870 Main Wheel Replacement, Main Wheel: step 1, image 2 of 2
    • While the Roomba is upside down, remove the 4.0mm screw surrounding the side brush using a Phillips #2 screwdriver.
    • Remove the brush.
  2. iRobot Roomba 870 Main Wheel Replacement: step 2, image 1 of 3 iRobot Roomba 870 Main Wheel Replacement: step 2, image 2 of 3 iRobot Roomba 870 Main Wheel Replacement: step 2, image 3 of 3
    • Unscrew the four 3.5mm screws on the back cover using a Phillips #2 screwdriver.
    • Remove the back cover.
  3. iRobot Roomba 870 Main Wheel Replacement: step 3, image 1 of 3 iRobot Roomba 870 Main Wheel Replacement: step 3, image 2 of 3 iRobot Roomba 870 Main Wheel Replacement: step 3, image 3 of 3
    • Unscrew the six 3.5mm screws using a Phillips #00 screwdriver. Each wheel has three screws.
    • Once all the screws are out, take out the wheels.
6 other people completed this guide.
Andrew Cabri
330 Reputation
2 Guides authored
Cal Poly, Team S14-G3, Banghart Spring 2017 Member of Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
4 Members
10 Guides authored
One Comment
In step 3, the screw positions are just a bit off. They are not under the corners of the battery but under into the wheel housing.
aarond12 - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 4,668
