iRobot Roomba 870 Side Brush Motor Replacement
  1. iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: step 1, image 1 of 3 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: step 1, image 2 of 3 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: step 1, image 3 of 3
    • Turn the Roomba over so that the back side is facing up.
    • Using the Phillips #00 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 870 Side Brush Motor Replacement: step 2, image 1 of 2 iRobot Roomba 870 Side Brush Motor Replacement: step 2, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the four 3.5mm screws that hold down the battery panel and rear panel.
  3. iRobot Roomba 870 Side Brush Motor Replacement: step 3, image 1 of 2 iRobot Roomba 870 Side Brush Motor Replacement: step 3, image 2 of 2
    • First remove the battery panel, which is the small rectangular.
    • After removing the battery panel, remove the rear panel.
  4. iRobot Roomba 870 Side Brush Motor Replacement: step 4, image 1 of 3 iRobot Roomba 870 Side Brush Motor Replacement: step 4, image 2 of 3 iRobot Roomba 870 Side Brush Motor Replacement: step 4, image 3 of 3
    • Remove the three small 3.5mm screws fastened to the motor housing.
    • After removing the screws, remove the motor housing from the rest of the Roomba.
  5. iRobot Roomba 870 Side Brush Motor Replacement: step 5, image 1 of 3 iRobot Roomba 870 Side Brush Motor Replacement: step 5, image 2 of 3 iRobot Roomba 870 Side Brush Motor Replacement: step 5, image 3 of 3
    • Remove the 2.5mm screw in the center of the motor housing using a Tri-Wing Y1 screwdriver.
    • After removing the screw, remove the top shell casing of the motor housing. Underneath, you will see a white gear with two screws next to it.
  6. iRobot Roomba 870 Side Brush Motor Replacement: step 6, image 1 of 3 iRobot Roomba 870 Side Brush Motor Replacement: step 6, image 2 of 3 iRobot Roomba 870 Side Brush Motor Replacement: step 6, image 3 of 3
    • Remove the two 2.5mm screws in the inner motor housing using a Phillips #00 screwdriver.
    • After removing the two screws, the motor will slide right out the back, and it can be replaced.
2 other people completed this guide.
Karthik Padmanabhan
175 Reputation
1 Guide authored
Cal Poly, Team S14-G3, Banghart Spring 2017 Member of Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 35
All Time: 3,654
