iRobot Roomba 880 Cleaning Head Replacement
  1. iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: step 1, image 1 of 3 iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: step 1, image 2 of 3 iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: step 1, image 3 of 3
    • Flip the Roomba over, wheel-side up.
    • Using a Phillips #1 screwdriver, loosen the four 15 mm screws illustrated. Two are located on the battery door, while two are on the bottom panel.
    • Remove the battery door, pulling straight up from the two indents above the screws.
  2. iRobot Roomba 880 Cleaning Head Replacement, Side Brush: step 2, image 1 of 2 iRobot Roomba 880 Cleaning Head Replacement, Side Brush: step 2, image 2 of 2
    • Using a flat head screwdriver, loosen the screw on the top of the side brush.
    • Remove side brush.
    • The bottom panel cannot be removed without first removing the side brush, so make sure to do this first.
  3. iRobot Roomba 880 Cleaning Head Replacement, Bottom Panel: step 3, image 1 of 1
    • Pull up on the bottom panel to remove.
  4. iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: step 4, image 1 of 2 iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: step 4, image 2 of 2
    • Reach underneath the dust bin, press the bin removal button, and pull out.
    • The bin removal button is located on the top edge of the bin.
  5. iRobot Roomba 880 Cleaning Head Replacement: step 5, image 1 of 2 iRobot Roomba 880 Cleaning Head Replacement: step 5, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the four 10 mm screws shown.
  6. iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: step 6, image 1 of 3 iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: step 6, image 2 of 3 iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: step 6, image 3 of 3
    • Remove the cleaning head by grabbing the two protruding tabs as shown, and pulling straight up.
Allie Ahern
130 Reputation
1 Guide authored
Cal Poly, Team S17-G4, Banghart Spring 2017 Member of Cal Poly, Team S17-G4, Banghart Spring 2017
CPSU-BANGHART-S17S17G4
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 2,273
