iRobot Roomba 880 Side Brush Motor Replacement
  1. iRobot Roomba 880 Side Brush Motor Replacement, Side Brush Motor: step 1, image 1 of 3 iRobot Roomba 880 Side Brush Motor Replacement, Side Brush Motor: step 1, image 2 of 3 iRobot Roomba 880 Side Brush Motor Replacement, Side Brush Motor: step 1, image 3 of 3
    • Remove the two Phillips #1 15mm screws holding the battery cover in place.
    • Once unscrewed, remove the battery cover and set aside.
  2. iRobot Roomba 880 Side Brush Motor Replacement: step 2, image 1 of 3 iRobot Roomba 880 Side Brush Motor Replacement: step 2, image 2 of 3 iRobot Roomba 880 Side Brush Motor Replacement: step 2, image 3 of 3
    • Remove two 15mm Phillips #1 screws beneath each side wheel.
  3. iRobot Roomba 880 Side Brush Motor Replacement: step 3, image 1 of 3 iRobot Roomba 880 Side Brush Motor Replacement: step 3, image 2 of 3 iRobot Roomba 880 Side Brush Motor Replacement: step 3, image 3 of 3
    • Remove the 10mm Phillips #1 screw holding the side brush in place.
    • Once unscrewed, remove the side brush and set aside.
  4. iRobot Roomba 880 Side Brush Motor Replacement: step 4, image 1 of 1
    • Remove the outer covering.
  5. iRobot Roomba 880 Side Brush Motor Replacement: step 5, image 1 of 2 iRobot Roomba 880 Side Brush Motor Replacement: step 5, image 2 of 2
    • Remove the three 10mm Phillips #1 screws holding down the side brush motor case.
  6. iRobot Roomba 880 Side Brush Motor Replacement: step 6, image 1 of 2 iRobot Roomba 880 Side Brush Motor Replacement: step 6, image 2 of 2
    • Take out the side brush motor case.
  7. iRobot Roomba 880 Side Brush Motor Replacement: step 7, image 1 of 1
    • Remove the 10mm Phillips #1 screw holding down the lid of the side brush motor case.
  8. iRobot Roomba 880 Side Brush Motor Replacement: step 8, image 1 of 3 iRobot Roomba 880 Side Brush Motor Replacement: step 8, image 2 of 3 iRobot Roomba 880 Side Brush Motor Replacement: step 8, image 3 of 3
    • Remove the piece holding the lid to the case.
    • Take off the lid and set aside.
  9. iRobot Roomba 880 Side Brush Motor Replacement: step 9, image 1 of 2 iRobot Roomba 880 Side Brush Motor Replacement: step 9, image 2 of 2
    • Remove the three 10mm Phillips #1 screws.
  10. iRobot Roomba 880 Side Brush Motor Replacement: step 10, image 1 of 3 iRobot Roomba 880 Side Brush Motor Replacement: step 10, image 2 of 3 iRobot Roomba 880 Side Brush Motor Replacement: step 10, image 3 of 3
    • Flip over and remove the side brush motor.
    • All done!
2 other people completed this guide.
agriewe
155 Reputation
1 Guide authored
Cal Poly, Team S17-G4, Banghart Spring 2017 Member of Cal Poly, Team S17-G4, Banghart Spring 2017
CPSU-BANGHART-S17S17G4
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,598
