iRobot Roomba 890 Side Brush Module Replacement
  1. iRobot Roomba 890 Side Brush Module Replacement, Side Brush Module: step 1, image 1 of 2 iRobot Roomba 890 Side Brush Module Replacement, Side Brush Module: step 1, image 2 of 2
    • Use a #2 Phillips screwdriver to remove the 7.7 mm screw securing the side brush head.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Side Brush Module Replacement: step 2, image 1 of 1
    • Place the Roomba with its bottom facing toward you.
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
    • Remove the battery cover.
  3. iRobot Roomba 890 Side Brush Module Replacement: step 3, image 1 of 2 iRobot Roomba 890 Side Brush Module Replacement: step 3, image 2 of 2
    • Pull directly up on the grey pull tabs to remove the battery.
  4. iRobot Roomba 890 Side Brush Module Replacement: step 4, image 1 of 1
    • Lift off the baseplate.
  5. iRobot Roomba 890 Side Brush Module Replacement: step 5, image 1 of 2 iRobot Roomba 890 Side Brush Module Replacement: step 5, image 2 of 2
    • Press the dustbin release button and pull it straight out.
  6. iRobot Roomba 890 Side Brush Module Replacement: step 6, image 1 of 2 iRobot Roomba 890 Side Brush Module Replacement: step 6, image 2 of 2
    • On the underside of the Roomba, use a Phillips #1 screwdriver to remove the two 15.5 mm screws.
  7. iRobot Roomba 890 Side Brush Module Replacement: step 7, image 1 of 2 iRobot Roomba 890 Side Brush Module Replacement: step 7, image 2 of 2
    • Grip the side brush module casing and lift it out vertically, perpendicular to the Roomba.
Dustin Staples
339 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 453
