iRobot Roomba 960 Filter Replacement
Vanessa Greyson
Vanessa Greyson and one other contributor
Last updated on April 17, 2017
5 minutes
Very easy
Introduction
Go to step 1
This guide will instruct you how to replace a filter in the iRobot Roomba 960. Filters should be replaced often with frequent use.
  1. iRobot Roomba 960 Filter Replacement, Filter: step 1, image 1 of 1
    • Orient the Roomba so that the device is on its wheels and the words can be read from left to right.
  2. iRobot Roomba 960 Filter Replacement: step 2, image 1 of 3 iRobot Roomba 960 Filter Replacement: step 2, image 2 of 3 iRobot Roomba 960 Filter Replacement: step 2, image 3 of 3
    • Press the large button on the Roomba that is located closest to you.
    • Pull to remove the dust bin.
  3. iRobot Roomba 960 Filter Replacement: step 3, image 1 of 3 iRobot Roomba 960 Filter Replacement: step 3, image 2 of 3 iRobot Roomba 960 Filter Replacement: step 3, image 3 of 3
    • With the dust bin completely detached from the Roomba, press the tab that is located on your right (there is a yellow arrow pointing to it).
    • Lift the red plastic cover to access the filter.
  4. iRobot Roomba 960 Filter Replacement: step 4, image 1 of 3 iRobot Roomba 960 Filter Replacement: step 4, image 2 of 3 iRobot Roomba 960 Filter Replacement: step 4, image 3 of 3
    • Using the yellow ribbon that is located at the top of the filter, pull it towards you.
    • Carefully remove the used filter.
Vanessa Greyson
471 Reputation
3 Guides authored
USF Tampa, Team 16-3, Blackwell Spring 2017 Member of USF Tampa, Team 16-3, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G3
4 Members
7 Guides authored
1 Guide Comment
I need to replace the red bin cover over the filter, do I need to unscrew the black piece or something or just try to pry it out. I don’t want to break it.
Sandra Freed - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 22
All Time: 2,239
