iRobot Roomba 980 Rear Wheels
  1. iRobot Roomba 980 Rear Wheels, Battery: step 1, image 1 of 1
    • Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
  2. iRobot Roomba 980 Rear Wheels: step 2, image 1 of 2 iRobot Roomba 980 Rear Wheels: step 2, image 2 of 2
    • Unscrew the back plate using a Phillips #1 screwdriver.
    • Carefully lift the panel up once the screws are removed.
  3. iRobot Roomba 980 Rear Wheels: step 3, image 1 of 2 iRobot Roomba 980 Rear Wheels: step 3, image 2 of 2
    • With both hands, grab the two black tabs on each end of the battery.
    • Pull the tabs upwards to remove the battery.
  4. iRobot Roomba 980 Rear Wheels, Rear Wheels: step 4, image 1 of 2 iRobot Roomba 980 Rear Wheels, Rear Wheels: step 4, image 2 of 2
    • Loosen the screw on the side brush.
    • Lift the side brush from the device.
  5. iRobot Roomba 980 Rear Wheels: step 5, image 1 of 2 iRobot Roomba 980 Rear Wheels: step 5, image 2 of 2
    • Unscrew the (2) 11.5mm screws using the Phillips #1 screwdriver.
    • Carefully remove the plate by lifting it off of the device.
  6. iRobot Roomba 980 Rear Wheels: step 6, image 1 of 2 iRobot Roomba 980 Rear Wheels: step 6, image 2 of 2
    • Removing the brush module may ease the removal of the wheel module
    • Locate the (3) 15.8mm gold Phillips #1 screws and unscrew them.
    • Lift the wheel module removing it from the vacuum.
    • Remove the other wheel by repeating these steps.
4 other people completed this guide.
Ernesto Rodriguez Romero
971 Reputation
4 Guides authored
USF Tampa, Team S14-G2, Boczar Fall 2017 Member of USF Tampa, Team S14-G2, Boczar Fall 2017
USFT-BOCZAR-F17S14G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 3,198
