iRobot Roomba S9 Plus Battery Module Replacement
  1. iRobot Roomba S9 Plus Battery Module Replacement, Battery Module: step 1, image 1 of 1
    • Using a Phillips #2 screwdriver, loosen the four screws in the bottom cover of the vacuum.
    • The screws cannot be removed and should be loosened.
  2. iRobot Roomba S9 Plus Battery Module Replacement: step 2, image 1 of 2 iRobot Roomba S9 Plus Battery Module Replacement: step 2, image 2 of 2
    • Lift up the bottom cover to reveal the battery module.
  3. iRobot Roomba S9 Plus Battery Module Replacement: step 3, image 1 of 2 iRobot Roomba S9 Plus Battery Module Replacement: step 3, image 2 of 2
    • Remove the 11mm Phillips #2 screw next to the battery module.
  4. iRobot Roomba S9 Plus Battery Module Replacement: step 4, image 1 of 3 iRobot Roomba S9 Plus Battery Module Replacement: step 4, image 2 of 3 iRobot Roomba S9 Plus Battery Module Replacement: step 4, image 3 of 3
    • Pull the pull tabs to release the battery.
    • If the battery isn't releasing, make sure to check the screw next to the battery.
6 other people completed this guide.
Jason Chu
288 Reputation
1 Guide authored
Cal Poly, Team S18-G3, White Winter 2020 Member of Cal Poly, Team S18-G3, White Winter 2020
CPSU-WHITE-W20S18G3
4 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 62
All Time: 7,687
