iRobot Roomba S9 Plus Corner Brush Replacement
  1. iRobot Roomba S9 Plus Corner Brush Replacement, Corner Brush: step 1, image 1 of 2 iRobot Roomba S9 Plus Corner Brush Replacement, Corner Brush: step 1, image 2 of 2
    • Place your Roomba upside down with the brush module facing you.
    • Push the grey tab by the top left corner of the brushes to release the retaining arm.
  2. iRobot Roomba S9 Plus Corner Brush Replacement: step 2, image 1 of 1
    • Lift the retaining arm away from the brushes.
  3. iRobot Roomba S9 Plus Corner Brush Replacement: step 3, image 1 of 1
    • Unscrew the four 11mm Phillips #2 screws holding the vacuum brushes in place.
  4. iRobot Roomba S9 Plus Corner Brush Replacement: step 4, image 1 of 2 iRobot Roomba S9 Plus Corner Brush Replacement: step 4, image 2 of 2
    • Remove the brush module by pulling up from the sides.
  5. iRobot Roomba S9 Plus Corner Brush Replacement: step 5, image 1 of 3 iRobot Roomba S9 Plus Corner Brush Replacement: step 5, image 2 of 3 iRobot Roomba S9 Plus Corner Brush Replacement: step 5, image 3 of 3
    • Unscrew the 7mm Phillips #2 screw holding the corner brush head in place.
  6. iRobot Roomba S9 Plus Corner Brush Replacement: step 6, image 1 of 1
    • Flip over the brush module to access the corner brush motor.
    • Unscrew the 15mm Phillips #0 screws holding the motor in place.
  7. iRobot Roomba S9 Plus Corner Brush Replacement: step 7, image 1 of 3 iRobot Roomba S9 Plus Corner Brush Replacement: step 7, image 2 of 3 iRobot Roomba S9 Plus Corner Brush Replacement: step 7, image 3 of 3
    • Carefully take the motor axle from its housing.
  8. iRobot Roomba S9 Plus Corner Brush Replacement: step 8, image 1 of 2 iRobot Roomba S9 Plus Corner Brush Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the wire connecting the motor using tweezers to pull out the connector.
2 other people completed this guide.
Lance Brown
348 Reputation
2 Guides authored
Cal Poly, Team S18-G3, White Winter 2020 Member of Cal Poly, Team S18-G3, White Winter 2020
CPSU-WHITE-W20S18G3
4 Members
9 Guides authored
2 Comments
Wish there was a way to replace that plastic. Stripped on mine.
Steve Yeung - Reply
Hi!
Is it possible to change just the plastic part where the brush screws in?
They did a really dumb thing and made a metal screw go in a plastic thread so of course, the plastic thread finally gave in.
Piotr - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 2,428
