iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement
  1. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement, Home Base Vacuum Bag: step 1, image 1 of 1
    • Open the vacuum bag container at the top of the home base.
  2. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: step 2, image 1 of 3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: step 2, image 2 of 3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: step 2, image 3 of 3
    • Grab the grey tab at the top of the bag and lift the bag straight out of the home base.
Charles D'Amico
223 Reputation
2 Guides authored
Cal Poly, Team S18-G3, White Winter 2020 Member of Cal Poly, Team S18-G3, White Winter 2020
CPSU-WHITE-W20S18G3
4 Members
9 Guides authored
2 Comments
what do you do if after you change the bag , the base says there is no bag? So I replaced the old bag after I pulled stuff out , still no change. now robot won’t work . On app it says end job stuck and all it did is move off base and turn around (after hit clean) help
shelleyandboys - Reply
Can we have a tear down of the base? The bag switch sometimes doesn't want to work properly. You can resolder a new switch or just solder a jumper so it always "senses" one. There's alot of screws, sensors, wires and a big motor. It helps to know where all the screws go.
ashimo0463 - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 1,405
