iRobot Roomba S9 Plus Left Wheel Module Replacement
  1. iRobot Roomba S9 Plus Left Wheel Module Replacement, Bottom Cover: step 1, image 1 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement, Bottom Cover: step 1, image 2 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement, Bottom Cover: step 1, image 3 of 3
    • Press the plastic hook under the lid.
    • Lift the handle and remove the bin.
  2. iRobot Roomba S9 Plus Left Wheel Module Replacement: step 2, image 1 of 1
    • Flip over the Roomba.
    • Loosen, but do not remove, the eight screws on the bottom using a Phillips #2 screwdriver.
  3. iRobot Roomba S9 Plus Left Wheel Module Replacement: step 3, image 1 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement: step 3, image 2 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement: step 3, image 3 of 3
    • Lift and remove the brush module.
    • Remove the bottom cover.
  4. iRobot Roomba S9 Plus Left Wheel Module Replacement, Left Wheel Module: step 4, image 1 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement, Left Wheel Module: step 4, image 2 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement, Left Wheel Module: step 4, image 3 of 3
    • Lift the clip sensor.
    • Press the latch on the inside of the left wheel module using your spudger, then lift and remove the module.
Patrick Bartlett
372 Reputation
3 Guides authored
Cal Poly, Team S18-G3, White Winter 2020 Member of Cal Poly, Team S18-G3, White Winter 2020
CPSU-WHITE-W20S18G3
4 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 33
All Time: 4,439
