iRobot Roomba i7 Plus Drive Wheel Replacement
  1. iRobot Roomba i7 Plus Drive Wheel Replacement, Side Brush: step 1, image 1 of 3 iRobot Roomba i7 Plus Drive Wheel Replacement, Side Brush: step 1, image 2 of 3 iRobot Roomba i7 Plus Drive Wheel Replacement, Side Brush: step 1, image 3 of 3
    • Flip the Roomba over so the underside is facing up.
    • Remove the 4 mm screw connecting the green side brush to the chassis using a Phillips #2 screwdriver.
    • Remove the green side brush.
  2. iRobot Roomba i7 Plus Drive Wheel Replacement, Back Plate: step 2, image 1 of 2 iRobot Roomba i7 Plus Drive Wheel Replacement, Back Plate: step 2, image 2 of 2
    • Remove the five screws from the underside of the Roomba using a Phillips #2 screwdriver.
    • Pull the back plate up and away from the Roomba to remove it from the device.
  3. iRobot Roomba i7 Plus Drive Wheel Replacement, Drive Wheel: step 3, image 1 of 2 iRobot Roomba i7 Plus Drive Wheel Replacement, Drive Wheel: step 3, image 2 of 2
    • Loosen the two captive screws from each wheel (four in total) using a Phillips #2 screwdriver.
    • Grab each wheel and gently pull them out.
Nathan Ely
531 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 321
