iRulu AX760 Camera Replacement
  1. iRulu AX760 Camera Replacement, Battery: step 1, image 1 of 3 iRulu AX760 Camera Replacement, Battery: step 1, image 2 of 3 iRulu AX760 Camera Replacement, Battery: step 1, image 3 of 3
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Camera Replacement: step 2, image 1 of 1
    • Open your tablet.
  3. iRulu AX760 Camera Replacement: step 3, image 1 of 1
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Camera Replacement: step 4, image 1 of 2 iRulu AX760 Camera Replacement: step 4, image 2 of 2
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. How To Solder and Desolder Connections
  5. iRulu AX760 Camera Replacement: step 5, image 1 of 1
    • Remove your old battery and replace it with the new battery.
  6. iRulu AX760 Camera Replacement, Camera: step 6, image 1 of 2 iRulu AX760 Camera Replacement, Camera: step 6, image 2 of 2
    • Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
  7. iRulu AX760 Camera Replacement: step 7, image 1 of 1
    • Pull the digitizer ribbon cables straight out of their sockets.
  8. iRulu AX760 Camera Replacement: step 8, image 1 of 1
    • Pull the camera out of the device.
Jamison Kritz
245 Reputation
2 Guides authored
IUPUI, Team S6-G4, Baechle Spring 2018 Member of IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 211
