iRulu AX760 Screen Display Replacement
  1. iRulu AX760 Screen Display Replacement, Battery: step 1, image 1 of 3 iRulu AX760 Screen Display Replacement, Battery: step 1, image 2 of 3 iRulu AX760 Screen Display Replacement, Battery: step 1, image 3 of 3
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Screen Display Replacement: step 2, image 1 of 1
    • Open your tablet.
  3. iRulu AX760 Screen Display Replacement: step 3, image 1 of 1
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Screen Display Replacement: step 4, image 1 of 2 iRulu AX760 Screen Display Replacement: step 4, image 2 of 2
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. How To Solder and Desolder Connections
  5. iRulu AX760 Screen Display Replacement: step 5, image 1 of 1
    • Remove your old battery and replace it with the new battery.
  6. iRulu AX760 Screen Display Replacement, Camera: step 6, image 1 of 2 iRulu AX760 Screen Display Replacement, Camera: step 6, image 2 of 2
    • Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
  7. iRulu AX760 Screen Display Replacement: step 7, image 1 of 1
    • Pull the digitizer ribbon cables straight out of their sockets.
  8. iRulu AX760 Screen Display Replacement: step 8, image 1 of 1
    • Pull the camera out of the device.
  9. iRulu AX760 Screen Display Replacement, Motherboard: step 9, image 1 of 2 iRulu AX760 Screen Display Replacement, Motherboard: step 9, image 2 of 2
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • There are two thin adhesive strips under the battery that run vertically along the left and right side.
    • Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
    • Do not use metal tools, and do not bend or puncture the battery.
  10. iRulu AX760 Screen Display Replacement: step 10, image 1 of 3 iRulu AX760 Screen Display Replacement: step 10, image 2 of 3 iRulu AX760 Screen Display Replacement: step 10, image 3 of 3
    • WARNING: SOLDERING IRONS BECOME EXTREMELY HOT. DO NOT TOUCH
    • For information on soldering and desoldering, check this link.
    • You must desolder several sets of contacts before attempting to remove the motherboard.
    • You must desolder the BAT (battery), LED, SPK (speaker), and ANT (antenna) contacts.
  11. iRulu AX760 Screen Display Replacement: step 11, image 1 of 2 iRulu AX760 Screen Display Replacement: step 11, image 2 of 2
    • Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
  12. iRulu AX760 Screen Display Replacement: step 12, image 1 of 2 iRulu AX760 Screen Display Replacement: step 12, image 2 of 2
    • Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard.
    • You will not need a metal spudger in order to re-place the motherboard
  13. iRulu AX760 Screen Display Replacement, Screen Display: step 13, image 1 of 1
    • Remove the plastic peel attached to the back of the screen display.
  14. iRulu AX760 Screen Display Replacement: step 14, image 1 of 2 iRulu AX760 Screen Display Replacement: step 14, image 2 of 2
    • Remove the grey wire from the back of the screen display.
  15. iRulu AX760 Screen Display Replacement: step 15, image 1 of 1
    • Insert the plastic spudger underneath the screen display and lift.
  16. iRulu AX760 Screen Display Replacement: step 16, image 1 of 2 iRulu AX760 Screen Display Replacement: step 16, image 2 of 2
    • Continue lifting the screen by hand and pull it out until it is completely removed.
Jamison Kritz
245 Reputation
2 Guides authored
IUPUI, Team S6-G4, Baechle Spring 2018 Member of IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 16
All Time: 578
