iView-776TPCII Camera Assembly Replacement
  1. iView-776TPCII Camera Assembly Replacement, Rear Panel: step 1, image 1 of 3 iView-776TPCII Camera Assembly Replacement, Rear Panel: step 1, image 2 of 3 iView-776TPCII Camera Assembly Replacement, Rear Panel: step 1, image 3 of 3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
  2. iView-776TPCII Camera Assembly Replacement: step 2, image 1 of 2 iView-776TPCII Camera Assembly Replacement: step 2, image 2 of 2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
  3. iView-776TPCII Camera Assembly Replacement, Camera Assembly: step 3, image 1 of 2 iView-776TPCII Camera Assembly Replacement, Camera Assembly: step 3, image 2 of 2
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
    • The camera module is located in the upper-right corner of the tablet.
    • Loosen the edges of the black tape covering the camera using the heavy-duty spudger.
    • Use the freed edges of the tape to gently remove the camera assembly from its plastic housing.
    • The camera assembly will still be connected to the rest of the device via a ribbon cable. Take care so as not to tear this connection.
  4. iView-776TPCII Camera Assembly Replacement: step 4, image 1 of 2 iView-776TPCII Camera Assembly Replacement: step 4, image 2 of 2
    Buy
    • Use tweezers to lift the cover off the top of the camera's ZIF adapter.
    • When reassembling the device, be sure to fully secure the ribbon cable from the camera back into the ZIF adapter.
    • Pull the assembly away from the motherboard with a set of tweezers to prepare for desoldering.
  5. iView-776TPCII Camera Assembly Replacement: step 5, image 1 of 1
    • Use the Portable Soldering Iron tool to heat the leads coming from the camera assembly to the motherboard, thereby breaking the connection.
    • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
    • Once heated, use tweezers to pull the wires free from their connections.
    • To ease reassembly, take note of which wire went to the positive and negative terminals.
Cory Gratzer
570 Reputation
5 Guides authored
IUPUI, Team 2-2, Baechle Fall 2015 Member of IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 18
All Time: 279
