ionvac SmartClean V2 Motor Wheel Replacement
  1. ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): step 1, image 1 of 2 ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): step 1, image 2 of 2
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
  2. ionvac SmartClean V2 Motor Wheel Replacement: step 2, image 1 of 3 ionvac SmartClean V2 Motor Wheel Replacement: step 2, image 2 of 3 ionvac SmartClean V2 Motor Wheel Replacement: step 2, image 3 of 3
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
  3. ionvac SmartClean V2 Motor Wheel Replacement: step 3, image 1 of 1
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
  4. ionvac SmartClean V2 Motor Wheel Replacement: step 4, image 1 of 2 ionvac SmartClean V2 Motor Wheel Replacement: step 4, image 2 of 2
    • Lift the top shell off carefully.
  5. ionvac SmartClean V2 Motor Wheel Replacement, Motor Wheel: step 5, image 1 of 1
    • Remove the 3 screws securing the cable assembly housing on the outer side of the motor wheel frame labeled either R (right wheel) or L (left wheel).
    • Set the cable assembly housing to the side.
  6. ionvac SmartClean V2 Motor Wheel Replacement: step 6, image 1 of 2 ionvac SmartClean V2 Motor Wheel Replacement: step 6, image 2 of 2
    • Unscrew the 3 screws securing the motor wheel frame.
    • Dislodge the wheel motor frame from the bottom shelf.
  7. ionvac SmartClean V2 Motor Wheel Replacement: step 7, image 1 of 1
    • Disconnect the cable attaching the motor wheel frame to the logic board.
  8. ionvac SmartClean V2 Motor Wheel Replacement: step 8, image 1 of 2 ionvac SmartClean V2 Motor Wheel Replacement: step 8, image 2 of 2
    • Carefully pull one end of the spring out of place to remove it from the motor wheel frame.
    • This will separate the motor wheel frame from the motor wheel assembly.
  9. ionvac SmartClean V2 Motor Wheel Replacement: step 9, image 1 of 1
    • Unscrew the five screws from the motor wheel assembly.
  10. ionvac SmartClean V2 Motor Wheel Replacement: step 10, image 1 of 2 ionvac SmartClean V2 Motor Wheel Replacement: step 10, image 2 of 2
    • Gently lift the clip on the side to separate the casing and expose the white plastic gears.
  11. ionvac SmartClean V2 Motor Wheel Replacement: step 11, image 1 of 1
    • Remove all but the largest gear to expose the silver screws and washers underneath.
    • Unscrew and remove the two silver screws along with each accompanying set of two washers.
    • Now you can remove the motor from the wheel assembly.
    • To clean the motor, use a soft cloth or alcohol wipe.
2 other people completed this guide.
Andre
175 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 41
All Time: 815
