jp.ik Leap T304 Battery Replacement Replacement
  1. jp.ik Leap T304 Battery Replacement Replacement, Rear Cover: step 1, image 1 of 1
    • First ensure your laptop is turned off and check if you have the necessary tools
  2. jp.ik Leap T304 Battery Replacement Replacement: step 2, image 1 of 2 jp.ik Leap T304 Battery Replacement Replacement: step 2, image 2 of 2
    • All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
  3. jp.ik Leap T304 Battery Replacement Replacement: step 3, image 1 of 3 jp.ik Leap T304 Battery Replacement Replacement: step 3, image 2 of 3 jp.ik Leap T304 Battery Replacement Replacement: step 3, image 3 of 3
    • With the opening tool, remove a rubber foot.
    • For this action you will have to exert some force, because the foot is glued with a resistant glue.
  4. jp.ik Leap T304 Battery Replacement Replacement: step 4, image 1 of 1
    • Remove all screws with a Philips screwdriver PH1
    • All screws are the same so don't worry about identifying them.
  5. jp.ik Leap T304 Battery Replacement Replacement: step 5, image 1 of 3 jp.ik Leap T304 Battery Replacement Replacement: step 5, image 2 of 3 jp.ik Leap T304 Battery Replacement Replacement: step 5, image 3 of 3
    • With the plastic tool, insert between the plastics and gently pry open.
    • With your fingers continue to force open the bottom cover on the side indicated in the figure.
    • You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
  6. jp.ik Leap T304 Battery Replacement Replacement: step 6, image 1 of 1
    • Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
    • To close the laptop just follow this guide in reverse.
  7. jp.ik Leap T304 Battery Replacement Replacement, Battery Replacement or Removal: step 7, image 1 of 1
    • Be careful to don't touch if not necessary any electrical part of the product and insure you're properly grounding.
  8. jp.ik Leap T304 Battery Replacement Replacement: step 8, image 1 of 1
    • Remove mylers shown in the picture.
    • Save them for battery assembly steps
  9. jp.ik Leap T304 Battery Replacement Replacement: step 9, image 1 of 2 jp.ik Leap T304 Battery Replacement Replacement: step 9, image 2 of 2
    • Disconnect the cable marked in the figure gently, pulling it out of the connector.
  10. jp.ik Leap T304 Battery Replacement Replacement: step 10, image 1 of 2 jp.ik Leap T304 Battery Replacement Replacement: step 10, image 2 of 2
    • Gently remove the battery.
    • CAUTION!!
    • Some products may have this battery fixed with double-sided adhesive tape. In these cases, use a wide spatula to remove the battery without bending it.
    • SAFETY WARNING!
    • Never bend or puncture the battery. Danger of explosion. If you detect a swollen or damaged battery, handle it with extreme care and place it in a protective container.
Nelson Oliveira
741 Reputation
4 Guides authored
jp.ik Member of jp.ik
Business
2 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 310
