jp.ik Leap T304 Keyboard Replacement
  1. jp.ik Leap T304 Keyboard Replacement, Rear Cover: step 1, image 1 of 1
    • First ensure your laptop is turned off and check if you have the necessary tools
  2. jp.ik Leap T304 Keyboard Replacement: step 2, image 1 of 2 jp.ik Leap T304 Keyboard Replacement: step 2, image 2 of 2
    • All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
  3. jp.ik Leap T304 Keyboard Replacement: step 3, image 1 of 3 jp.ik Leap T304 Keyboard Replacement: step 3, image 2 of 3 jp.ik Leap T304 Keyboard Replacement: step 3, image 3 of 3
    • With the opening tool, remove a rubber foot.
    • For this action you will have to exert some force, because the foot is glued with a resistant glue.
  4. jp.ik Leap T304 Keyboard Replacement: step 4, image 1 of 1
    • Remove all screws with a Philips screwdriver PH1
    • All screws are the same so don't worry about identifying them.
  5. jp.ik Leap T304 Keyboard Replacement: step 5, image 1 of 3 jp.ik Leap T304 Keyboard Replacement: step 5, image 2 of 3 jp.ik Leap T304 Keyboard Replacement: step 5, image 3 of 3
    • With the plastic tool, insert between the plastics and gently pry open.
    • With your fingers continue to force open the bottom cover on the side indicated in the figure.
    • You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
  6. jp.ik Leap T304 Keyboard Replacement: step 6, image 1 of 1
    • Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
    • To close the laptop just follow this guide in reverse.
  7. jp.ik Leap T304 Keyboard Replacement, Battery Replacement or Removal: step 7, image 1 of 1
    • Be careful to don't touch if not necessary any electrical part of the product and insure you're properly grounding.
  8. jp.ik Leap T304 Keyboard Replacement: step 8, image 1 of 1
    • Remove mylers shown in the picture.
    • Save them for battery assembly steps
  9. jp.ik Leap T304 Keyboard Replacement: step 9, image 1 of 2 jp.ik Leap T304 Keyboard Replacement: step 9, image 2 of 2
    • Disconnect the cable marked in the figure gently, pulling it out of the connector.
  10. jp.ik Leap T304 Keyboard Replacement: step 10, image 1 of 2 jp.ik Leap T304 Keyboard Replacement: step 10, image 2 of 2
    • Gently remove the battery.
    • CAUTION!!
    • Some products may have this battery fixed with double-sided adhesive tape. In these cases, use a wide spatula to remove the battery without bending it.
    • SAFETY WARNING!
    • Never bend or puncture the battery. Danger of explosion. If you detect a swollen or damaged battery, handle it with extreme care and place it in a protective container.
  11. jp.ik Leap T304 Keyboard Replacement, Keyboard: step 11, image 1 of 1
    • After remove the battery, you need to remove the black mylar that covers keyboard connector.
  12. jp.ik Leap T304 Keyboard Replacement: step 12, image 1 of 2 jp.ik Leap T304 Keyboard Replacement: step 12, image 2 of 2
    • After removing the adhesive tape covering the connector, use the plastic tool to carefully lift the black component that locks the keyboard tape.
    • Then gently pull the keyboard cable and release it.
  13. jp.ik Leap T304 Keyboard Replacement: step 13, image 1 of 1
    • After you need to remove the I/O board. It is fixed with two screws.
  14. jp.ik Leap T304 Keyboard Replacement: step 14, image 1 of 1
    • Follow the same procedure as to disconnect the keyboard flat cable for the cabe attached to the I/O board.
  15. jp.ik Leap T304 Keyboard Replacement: step 15, image 1 of 1
    • Under the I/O board there's a hole that you need to insert a tool and push the keyboard at the same time you pull the plastic as show in the picture. This plastic holds the keyboard.
    • There are more holders, but you just need to open one, the others will sag when you pull the keyboard smoothly
  16. jp.ik Leap T304 Keyboard Replacement: step 16, image 1 of 2 jp.ik Leap T304 Keyboard Replacement: step 16, image 2 of 2
    • Smoothly lift the ktboard from its position.
  17. jp.ik Leap T304 Keyboard Replacement: step 17, image 1 of 1
    • Finally the keyboard is detached. When assemble the new keyboard do all this procedure in reverse order, taking extra care to don't touch the cable contacts, or bend them.
Nelson Oliveira
741 Reputation
4 Guides authored
jp.ik Member of jp.ik
Business
2 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 19
All Time: 269
