nikon s3700 LCD Display Screen Replacement
  1. nikon s3700 LCD Display Screen Replacement, Removing the Screws: step 1, image 1 of 3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: step 1, image 2 of 3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: step 1, image 3 of 3
    • group screws according to color code.
    • Remove exterior screws
  2. nikon s3700 LCD Display Screen Replacement, Replace LCD: step 2, image 1 of 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: step 2, image 2 of 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: step 2, image 3 of 3
    • Remove Rear casing.
    • With a thin blade, gently lift the top tight hand side of the buttons board releasing a peg from a hole on the midframe below. Whilst doing so, gently push on the top left hand side in order to release the buttons board from a clip. At the same time, the bottom left hand corner wil be released from another clip.
    • Flip over rear buttons board to expose LCD ZIF clamp.
    • Flip open the clamp of the ZIF connector and slide the ribbon cable out. (The connector may have a piece of sticky tape over it. Removing this may well open the connector clamping bar.)
    • The ZIF clamp is very fragile so please use caution when releasing the ZIF clamp. It breaks easily.
    • Remove the LCD.
2 other people completed this guide.
Sales Cameraparts4you
3,242 Reputation
20 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 21
All Time: 484
