plantronics Voyager pro Battery Replacement
Video Overview
  1. plantronics Voyager pro Battery Replacement, Battery: step 1, image 1 of 1
    • order your battery
  2. plantronics Voyager pro Battery Replacement: step 2, image 1 of 1
    • separate rubber case from back of earpiece. you don't need to remove it completely like I did.
  3. plantronics Voyager pro Battery Replacement: step 3, image 1 of 1
    • rotate the back away from the case. its basically glued in place with no other fasteners
  4. plantronics Voyager pro Battery Replacement: step 4, image 1 of 1
    • you will need to slowly cut through the foam to separate the wires from the battery. then use a soldering iron to desolder the old battery from the board these connections go through the entire board.
  5. plantronics Voyager pro Battery Replacement: step 5, image 1 of 1
    • solder the new battery in and test the charging before reassembly.
    • the new battery I ordered was slightly larger but it fit with no problems. I found the wires inside this device to be fairly robust and did not have any issues with wires breaking or dislodging.
    • When I re-assembled I used small amounts of gorilla glue for both the case and the rubber cover. it worked very well and has worked well since. for more details I put together a short video you can check out.
5 other people completed this guide.
Dan Dunham
3,351 Reputation
29 Guides authored
One Comment
I accomplished this battery replacement. I was successful. However in my opinion, this device was not meant to have this repair done. It is a “fiddley” affair, but possible. I think it took me two hours, at my leisure. Probably better off replacing the device. Unless…. your just that type who enjoys fiddling around.
Leslie Womelsdorff - Reply
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 74
All Time: 4,609
