removal of bottom case
  1. removal of bottom case, removal of bottom case: step 1, image 1 of 2 removal of bottom case, removal of bottom case: step 1, image 2 of 2
    • remove the feet with a spudger
  2. removal of bottom case: step 2, image 1 of 2 removal of bottom case: step 2, image 2 of 2
    • Remove the 11 screw with a PH0 screwdriver.
    • The screws are identical
  3. removal of bottom case: step 3, image 1 of 2 removal of bottom case: step 3, image 2 of 2
    • Insert a spudger between the bottom cover and the keyboard module, then go around the whole cover to uncip everything.
    • Remove the bottom cover from the computer.
  4. removal of bottom case: step 4, image 1 of 1
    • You now have acces to the inside of the machine.
to reassemble the computer, clip back the cover to the computer then screw it back, and finally put the bottom stickers/feet back on (the thicker one goes on the screen side)
Special thanks to these translators:
fr en
100%
Léo FRAYSSE is helping us fix the world! Want to contribute?
Start translating ›
Léo FRAYSSE
1,379 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,098
