removing the HP Elitebook 6930p Optical Drive
  1. removing the HP Elitebook 6930p Optical Drive, Battery Removal: step 1, image 1 of 3 removing the HP Elitebook 6930p Optical Drive, Battery Removal: step 1, image 2 of 3 removing the HP Elitebook 6930p Optical Drive, Battery Removal: step 1, image 3 of 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. removing the HP Elitebook 6930p Optical Drive, Optical Drive: step 2, image 1 of 3 removing the HP Elitebook 6930p Optical Drive, Optical Drive: step 2, image 2 of 3 removing the HP Elitebook 6930p Optical Drive, Optical Drive: step 2, image 3 of 3
    • With the bottom of the laptop facing up and the front toward you locate and loosen the M2.5×9.0 captive screw holding the optical drive into the laptop.
    • Insert a flat-bladed screwdriver or similar tool into the optical drive tab access hole and press the tab to the left to release the optical drive from the computer
    • The optical drive will unlock and pop out of the side of the laptop. You are now able to temove the optical drive from the laptop.
7 other people completed this guide.
Richdave
32,365 Reputation
30 Guides authored
Master Techs Member of Master Techs
Community
327 Members
1,697 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,193
