the Nokia 6230b Speaker Replacement
  1. the Nokia 6230b Speaker Replacement, Back Cover: step 1, image 1 of 1
    • Press down the button on the back panel.
  2. the Nokia 6230b Speaker Replacement: step 2, image 1 of 2 the Nokia 6230b Speaker Replacement: step 2, image 2 of 2
    • Push the back cover upwards.
  3. the Nokia 6230b Speaker Replacement: step 3, image 1 of 2 the Nokia 6230b Speaker Replacement: step 3, image 2 of 2
    • Remove the back cover from the phone.
  4. the Nokia 6230b Speaker Replacement, Front Cover: step 4, image 1 of 1
    • Press the silver button on the top of the phone.
  5. the Nokia 6230b Speaker Replacement: step 5, image 1 of 1
    • Slide your thumbnail down the case seam to separate the rest of the case.
  6. the Nokia 6230b Speaker Replacement: step 6, image 1 of 1
    • Gently remove the case.
    • Careful! Do not bend the plastic tabs.
  7. the Nokia 6230b Speaker Replacement, Motherboard: step 7, image 1 of 2 the Nokia 6230b Speaker Replacement, Motherboard: step 7, image 2 of 2
    • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
  8. the Nokia 6230b Speaker Replacement: step 8, image 1 of 2 the Nokia 6230b Speaker Replacement: step 8, image 2 of 2
    • Remove the panel that covers the motherboard.
    • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
  9. the Nokia 6230b Speaker Replacement: step 9, image 1 of 1
    • Remove the LCD screen frame.
  10. the Nokia 6230b Speaker Replacement: step 10, image 1 of 1
    • Remove the motherboard.
  11. the Nokia 6230b Speaker Replacement, Speaker: step 11, image 1 of 1
    • Locate the speaker on the back of the removed panel.
  12. the Nokia 6230b Speaker Replacement: step 12, image 1 of 1
    • Use nails to gently lift the speaker up; speaker may be slightly glued to the panel.
  13. the Nokia 6230b Speaker Replacement: step 13, image 1 of 1
    • When the speaker is loose, gently lift the speaker out of the panel.
Job Jao
37 Reputation
2 Guides authored
Cal Poly, Team 3-27, Regan Fall 2010 Member of Cal Poly, Team 3-27, Regan Fall 2010
CPSU-REGAN-F10S3G27
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 2,831
