iPhone 4 Logic Board Replacement
Notice: You are editing a prerequisite guide. Any changes you make will affect all 11 guides that include this step.
English
Korean
Translating step 8
Step 8
iPhone 4 Logic Board Replacement: step 0, image 1 of 3 iPhone 4 Logic Board Replacement: step 0, image 2 of 3 iPhone 4 Logic Board Replacement: step 0, image 3 of 3
  • Use an iPod opening tool to slightly lift the top edge of the Wi-Fi antenna away from the logic board.
  • Use the tip of a spudger to pull the Wi-Fi retaining clips away from the inner frame.
  • Remove the Wi-Fi antenna from the iPhone. Make sure you don't lose the metal clips on the top of the cover where the 4.8mm screw attaches or the 4.8mm screw. That's the primary reason for abnormal Wi-Fi performance after the reassembly.
  • Before reassembly, be sure to clean all metal-to-metal contact points on the connector cover with a de-greaser such as Windex. The oils on your fingers have the potential to cause wireless interference issues. Do not clean the connectors themselves with Windex.
Insert translation here
