velocity micro tablet T301 Screen Display. Replacement
  1. velocity micro tablet T301 Screen Display. Replacement, Screen Display.: step 1, image 1 of 1
    • Insert the plastic opening tool in the SD port. The edge point should be pointed towards the rear panel.
  2. velocity micro tablet T301 Screen Display. Replacement: step 2, image 1 of 1
    • Insert a small opening tool between the rear panel and the tablet.
  3. velocity micro tablet T301 Screen Display. Replacement: step 3, image 1 of 1
    • The large opening tool is not needed any more.
  4. velocity micro tablet T301 Screen Display. Replacement: step 4, image 1 of 2 velocity micro tablet T301 Screen Display. Replacement: step 4, image 2 of 2
    • Move the small tool opener around the rear panel to free the 12 edges.
  5. velocity micro tablet T301 Screen Display. Replacement: step 5, image 1 of 1
    • Using PH0 Phillips Driver, remove the 4 Screws in the Metal part.
  6. velocity micro tablet T301 Screen Display. Replacement: step 6, image 1 of 1
    • Using a plastic Spudger remove the battery connector.
  7. velocity micro tablet T301 Screen Display. Replacement: step 7, image 1 of 1
    • Using PH0 Phillips Driver, remove the 12 Screws in the cover.
  8. velocity micro tablet T301 Screen Display. Replacement: step 8, image 1 of 1
    • Place a metal Spudger between the tablet and the back cover.
  9. velocity micro tablet T301 Screen Display. Replacement: step 9, image 1 of 1
    • Move the spudger around the tablet to release the clips attached to the tablet.
  10. velocity micro tablet T301 Screen Display. Replacement: step 10, image 1 of 1
    • Use a plastic spudger to release the connection between the speakers and the motherboard as shown in the picture.
  11. velocity micro tablet T301 Screen Display. Replacement: step 11, image 1 of 1
    • Using a metal spudger to remove the top plug connector from the motherboard.
  12. velocity micro tablet T301 Screen Display. Replacement: step 12, image 1 of 2 velocity micro tablet T301 Screen Display. Replacement: step 12, image 2 of 2
    • Use a metal spudger to remove both screen cable connectors.
  13. velocity micro tablet T301 Screen Display. Replacement: step 13, image 1 of 1
    • use openning tools to remove the motherboard.
  14. velocity micro tablet T301 Screen Display. Replacement: step 14, image 1 of 1
    • Remove the motherboard cover to reach in the screen display.
James Napoleon
101 Reputation
1 Guide authored
USF Tampa, Team 1-6, Cagle Fall 2016 Member of USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 76
