why! N650DU Motherboard
  1. why! N650DU Motherboard, The Batteries: step 1, image 1 of 3 why! N650DU Motherboard, The Batteries: step 1, image 2 of 3 why! N650DU Motherboard, The Batteries: step 1, image 3 of 3
    • Unlock the button without spring
    • Slide the battery up while unlocking the button with spring
  2. why! N650DU Motherboard, Access to major components: step 2, image 1 of 3 why! N650DU Motherboard, Access to major components: step 2, image 2 of 3 why! N650DU Motherboard, Access to major components: step 2, image 3 of 3
    • Unscrew the two large screws circled in red
    • Unscrew the two small screws circled in green
    • Slide the plate down and lift the
  3. why! N650DU Motherboard, RAM memory: step 3, image 1 of 3 why! N650DU Motherboard, RAM memory: step 3, image 2 of 3 why! N650DU Motherboard, RAM memory: step 3, image 3 of 3
    • Spread the two arms holding the RAM bar
    • Remove the RAM card
  4. why! N650DU Motherboard, SSD disk: step 4, image 1 of 2 why! N650DU Motherboard, SSD disk: step 4, image 2 of 2
    • Unscrew the screw circled in red
    • Remove the SSD
  5. why! N650DU Motherboard, Hard disk: step 5, image 1 of 3 why! N650DU Motherboard, Hard disk: step 5, image 2 of 3 why! N650DU Motherboard, Hard disk: step 5, image 3 of 3
    • Pull the black tab up
  6. why! N650DU Motherboard, CD / DVD RW drive: step 6, image 1 of 3 why! N650DU Motherboard, CD / DVD RW drive: step 6, image 2 of 3 why! N650DU Motherboard, CD / DVD RW drive: step 6, image 3 of 3
    • Push the drive to the location indicated by the green arrow
    • Remove the drive from its location
  7. why! N650DU Motherboard, Carte WLAN: step 7, image 1 of 3 why! N650DU Motherboard, Carte WLAN: step 7, image 2 of 3 why! N650DU Motherboard, Carte WLAN: step 7, image 3 of 3
    • Disconnect the WLAN card in the direction of the red arrow
    • Unhook the two connectors circled in green on the WLAN card
  8. why! N650DU Motherboard, Processor: step 8, image 1 of 3 why! N650DU Motherboard, Processor: step 8, image 2 of 3 why! N650DU Motherboard, Processor: step 8, image 3 of 3
    • Unscrew the four screws circled in red
    • Lift the radiator with the black label
  9. why! N650DU Motherboard: step 9, image 1 of 3 why! N650DU Motherboard: step 9, image 2 of 3 why! N650DU Motherboard: step 9, image 3 of 3
    • Push the lever in the direction of the red arrow while pushing it in
    • Lift the lever in the direction of the green arrow
    • Do not touch the bottom of the processor and take it by the sides
  10. why! N650DU Motherboard, The fan: step 10, image 1 of 3 why! N650DU Motherboard, The fan: step 10, image 2 of 3 why! N650DU Motherboard, The fan: step 10, image 3 of 3
    • Unscrew the two screws circled in red
    • Disconnect the connector surrounded in green
    • Remove the fan by lifting the blue framed tab
  11. why! N650DU Motherboard, Pile BIOS: step 11, image 1 of 2 why! N650DU Motherboard, Pile BIOS: step 11, image 2 of 2
    • Remove the battery using a flat screwdriver
  12. why! N650DU Motherboard, The keyboard: step 12, image 1 of 3 why! N650DU Motherboard, The keyboard: step 12, image 2 of 3 why! N650DU Motherboard, The keyboard: step 12, image 3 of 3
    • Unscrew the circled screws in red and green
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
  13. why! N650DU Motherboard: step 13, image 1 of 3 why! N650DU Motherboard: step 13, image 2 of 3 why! N650DU Motherboard: step 13, image 3 of 3
    • Remove the red circled connector
    • Pull the white drawer that holds the connector circled in blue in the direction of the green arrow
    • Remove the connector surrounded in blue
  14. why! N650DU Motherboard, Motherboard: step 14, image 1 of 3 why! N650DU Motherboard, Motherboard: step 14, image 2 of 3 why! N650DU Motherboard, Motherboard: step 14, image 3 of 3
    • Lift the two black flaps
    • Remove the two connectors circled in red
  15. why! N650DU Motherboard: step 15, image 1 of 3 why! N650DU Motherboard: step 15, image 2 of 3 why! N650DU Motherboard: step 15, image 3 of 3
    • Remove the thirteen screws circled in red
    • Remove the top cover
  16. why! N650DU Motherboard: step 16, image 1 of 3 why! N650DU Motherboard: step 16, image 2 of 3 why! N650DU Motherboard: step 16, image 3 of 3
    • Lift the blue flap that holds the connector circled in green
    • Disconnect the red circled connector
  17. why! N650DU Motherboard: step 17, image 1 of 3 why! N650DU Motherboard: step 17, image 2 of 3 why! N650DU Motherboard: step 17, image 3 of 3
    • Disconnect the two connectors located in the green zone
    • Disconnect the connector surrounded in blue
  18. why! N650DU Motherboard: step 18, image 1 of 3 why! N650DU Motherboard: step 18, image 2 of 3 why! N650DU Motherboard: step 18, image 3 of 3
    • Remove the Micro SD port cover that is circled in green if there is one
    • Unscrew the three screws circled in red
    • Carefully remove the motherboard
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 580
